-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Ignition Troubleshooting help (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/247208-ignition-troubleshooting-help.html)
vahday 10-21-2005 10:50 AM
All,
I am trying to troubleshoot a problem with my 1974 1.8 (carb conversion). Basically, the car will not start but will turnover easily. I have been following the Ignition Troubleshooting documents in the Tech Info Center and I believe the problem is with my coil. I found that I have +12 volts to the coil with the ignition on, however, when I attempt to check for a spark between the coil plug wire and ground (as suggested by Dave D) I do not get a spark. This makes me think it is the coil. However, I do get a spark between the temporary wire (connected between coil negative and ground) and ground when I disconnect it. Should a spark occur at this spot? Am I doing the procedure wrong? Any help would be appreciated.
914GT 10-21-2005 11:54 AM
First verify that you have 12V on the coil while the engine is cranking. I have seen the ignition switches wear out and cause the 12V to drop out when in the start position.
