1974 914-1.8 bad idle after initial start
My 914 with stock 1.8 FI starts up fine with a high idle of 2000 rpm. After about 30 sec. the idle drops and engine stalls. I have changed the gaskets at the oil breather base (oil filler cap). Aside from possible air leaks what is the proper method of adjusting the idle and fuel mixture? Do I need to get an exhaust gas analyser to set the mixture correctly? Adjusting the air screw on the throttle body doesn't seem to help.
Any suggestions would be welcomed.
Tom
Old 11-30-2005, 08:27 PM
