Can people post their car's HP, and specify their engine setup to produce this HP (example: compression ratio, cam, bore, engine type, etc.)
Want to get a general idea of the different setups and HP gain over the stock setup. |
3.2 DME 911 motor
964 cams B&B Headers Dual Supertrap exhaust Basically stock motor Aprox 250+HP
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
2.7L
Solex cams 9.7:1 pistons Webers Headers MSD This combo (with less compression & a bit milider cams) pulls 210 HP or so on the dyno per Andersons book.
JPIII Early Boxster |
Holy horsepower Batman!!
Stock 2.0 Around 100,000 miles Maybe 50hp Keith
74 914 2.0 (sold) 96 328is |
Stock 3.0 8:5:1
Headers Webers 200 - 210 Very torquey Very Fast
A couple of month back, Grassroots Motors Sports magazine had an article on modifiying a 'stock' FI 2.0 and motor. They were able to get about 110+/- HP
76 w/2056cc FI
96mm p&c's stock cam Pertronix w/MSD 2.0l heads with 42x38 valves ported and polished balanced rotating parts SSI 2.0l HE's Bursch Exhaust tuned MPS 95hp on a rolling dyno so that about 105-110hp on a engine dyno Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
Don't know
But it goes like stink.
2.0L us pistons Web 86B cam dual valve springs 44IDF's No interior, no sound deadening/ Corbeau froza seats Fiberglass bumpers/ front and rear Valance too. Doesn't every 10lbs = 1 HP |
Geoff, We have almost the same engine setup. Except I'm running Web cam. Haven't dyno my car yet. Did you get a chance to measure your 0-60 time? and 1/4 mile time? btw, I also have a 76 914 2.0L+ FI. |
No, I have never drag raced the car but my son might take it this summer for a fun run.
With 205x5015's Dunlop SP8000 it is quick which is nice for autoxing. That is where does well against other 914's set up about the same. It can't just be my driving! ![]() I am competitive with other guys running Kumo's and Hoosiers in the local GTU class. I have the MPS tuned alittle rich for WOT at about 12.7 to 1. Highway cruzin' it gets about 25mpg I am not a carb guy as I ripped them off and reinstalled the FI. Geoff
'73 2.0
Euro P&C's Weber 44 idf's Web-cam 050 dizzy stock headers w/o heat exchangers 2.0 911 muffler stock ignition I don't know how much horse power, over a 100 is all I know!
Raby 2056 96X71
2.0 heads stock valves w/ port and polish 8.8:1 dual valve springs split duration web cam webber 44's it got peak 131hp @ 6k and 130lbs tq @4.5K on an engine dyno. - Tony |
76 914 2350 lbs
Modified DZ 302 418 hp @ 7000 rpm 375 ft/lbs @ 6k Nobody said it had to be 100% P-car. Pat
pat --------------- 86 930 76 914 5.0 |
2615 cc ENGINE #1 220 HP 240 FT/LB TORQUE
LONGBLOCK -Case: 1.7L bus, CB-series -Crank: 80mm, welded, counterweighted, Chevy journals, balanced -Rods: 5.5" H-beam, forged, ARP bolts, balanced -Flywheel: 215mm bus, lightened, pilot bearing installed in center, balanced -Oil pump: 26mm, aluminum body (replaced with a melling) -Oil filtering: stock filter mount using smaller filter size (for clearance) -Oil: Torco full racing synthetic -Windage: stock windage tray -Cylinders: 102mm LN Engineering Nickies -Pistons: LN Engineering, by JE, forged, special crown design, balanced -Rings: special set, includes some 911 3.8L RSR pieces -Cylinder/Head Studs: LN Engineering -Deck height: 0.035" -Compression ratio: 9.2:1 -Heads: FAT-reworked 914 2.0 heads, 48x38 Manley SS valves, full P&P (no welding), deshrouded chambers -Camshaft: Webcam, hydraulic, custom grind -Lifters: Webcam, hydraulic -Pushrods: Chromoly -Rocker Arms: Pauter, 1.48:1 2332 cc ENGINE #2 175 HP 188 FT/LB TORQUE LONGBLOCK -Case: GA-series -Crank: 71mm Stock 2L Crank Counterweighed -Rods: 2L Rods, ARP bolts, balanced -Oil pump: Stock Pump -Oil filtering: Stock filter mount using smaller filter size (for clearance) -Oil: Torco full racing synthetic -Windage: stock windage tray -Cylinders: 102mm LN Engineering Nickies -Pistons: LN Engineering, by JE, forged, special crown design, balanced -Rings: special set, includes some 911 3.8L RSR pieces -Cylinder/Head Studs: LN Engineering -Compression ratio: 9.5:1 -Heads: 914 2.0 heads mild exhaust port work, coated intakes and exhausts -Camshaft: Webcam, hydraulic, custom grind -Lifters: Webcam, hydraulic -Pushrods: Chromoly -Rocker Arms: Pauter, 1.48:1 -All engine parts cryo'ed by Perfcryo, GA Both engines are set up with our LNefi autronic based fuel injection system. Take care, Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Performance Products Last edited by cnavarro; 05-28-2002 at 08:54 PM.. |
