914/6 Heater flapper boxes
Hi all,
I'm restoring my genuine '70 2.0 Porsche 914/6. I finally found a pair of OEM heat-exchangers, but still need the heater flapper boxes which attaches to the heat-exchangers in order to direct hot air into the interior compartment. My question is: Does anybody know if these flapper boxes are interchangeable between the 4-cylinder's and the 6's heat exchangers? They seems to be different parts, given the different parts nrs, but on pictures they look quite the same. Is the difference of parts nr because of aftermarket (Dansk) vs (Porsche) OEM parts, or is it really specific to the 6's heat exchangers? In anyway, the boxes for the 911 of the same era look quite different and also have different parts nrs. I would appreciate any advice! Thanx and Merry Xmas to you all! |
flapper boxes
i used 914 regular flapper boxes when I did
my conversion they seem to work ok |
I do believe they are the same part.
I'm running brand new one's from Performance products.
There the same as the 4 banger. -Steve
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
Actually, the heater flapper boxes were different between a 4 and a 6. The original six heater flapper boxes had a hole in the end of the the exhaust cover. Why, I don't know....
There is no functionality difference. Porsche discontinued the six flapper boxes and superceded them with the four cylinder ones.
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
Yes you are correct, the 4 banger one's fit my factory 914-6 heat exchangers with no modifications.
Hey, you are both right. The 6 heater flapper boxes are different but you can use the 4s on the 6 heat exchangers. Unless you are a concours nut, but then you have far greater issues ;>)
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
