Stroke of 4 cyl motors
I am new the the 914 engines. What is the stroke of the 3 different displacement engines used in the 914?
Old 02-16-2001, 08:46 AM
Welcome!
You can find lots of great info here at the Pelican Parts (PP) web site.
Check out: http://www.pelicanparts.com/914/914tech_specs.htm
1.7L & 1.8L specs: http://www.pelicanparts.com/914/technical_specs/914_17_18_tech_specs.htm
2.0L specs: http://www.pelicanparts.com/914/technical_specs/914_20_tech_specs.htm
BTW: 1.7L & 1.8L stroke is 66mm, 2.0L is 71mm.
Old 02-16-2001, 09:47 AM
thanks for the links and info.
Old 02-16-2001, 07:42 PM
