Renewing Seat Belts
Is the dealer the only source of stock replacement seat belts? Mine look good, but they are 26 years old. Is there a limit to age on these things?
scott |
If they work good and aren't frayed then you could continue to use them. If you do any driver's ed or time trials where a 5 point harness is required then there is a 5 year rule for age and in all cases no frayed areas or cuts are allowed. The retractor and belts from a 924 will also work.
