-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   parts needed (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2649-parts-needed.html)
scotty914 03-06-2001 04:15 PM
parts needed
i need the plastic clips that secure the wiring harness to the engine tin or a good replacement ( not porsche is okay ) PP does not even have a part number on them ( not like it is a commonly requested part ) they are basicly zip ties with mounting studs on the back, i did not fiqure how to get them off till i broke them (all)
any help is appreciated
scott thacher
75 1.8 under construction
75 under rust
(fine german rust)
HMeeder 03-06-2001 05:25 PM
Scott:
I don't know if this would work but there are many types of clips and cable stays at the electrical department of your local Home Depot or the like. I saw them several weeks ago and thought that there may be a good use for them like what you mention.
Motor On!
Herb
'72 1.7 Tangerine 'Teen
'74 2.0 Red Rustmobile
bowlsby 03-06-2001 09:15 PM
Scott, what clips and which harness are you referring to? I've seen many 914 harnesses, but not one with any sort of clips.
Are you referring to the nylon clips for the fuel lines? I have a part number for that one.
