-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Conversion throttle cable bracket? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/264968-conversion-throttle-cable-bracket.html)
Grantsfo 02-06-2006 10:53 AM
I'm preparing for a 2.4 6 cylinder with triple webers conversion into my 74 1.8.
I'm looking for recomendations on how how to hook up throttle cable.
John Rogers 02-08-2006 08:16 AM
There are two possibilities: first is a stock setup with the bellcrank and other stock parts. Second is to use the 4 cylinder cable (as I did) and make a small bracket out of aluminum angle stock and bolt it onto the rear area of the engine. I feel the 4 cylinder cable is simpler, but some may disagree.
Dave at Pelican Parts 02-08-2006 09:22 AM
We used to carry a bolt-on bracket for a 911 bellcrank, but that seems to have been discontinued. It mounted further back than the stock Six bellcrank, but used the (cheaper!) 914-4 throttle cable and some 911 throttle linkage rods. You may be able to fab some equivalent up just from the pics in our 914-6 conversion section...
Rich Johnson (a914guy@aol) makes a replica of the stock Six setup. Requires drilling and tapping a particular boss on the intermediate plate.
Or just put a nice beefy bracket somewhere in the engine bay and run the cable direct to the cross-shaft of the carbs, like a four-cylinder setup would.
--DD
Jared at Pelican Parts 02-08-2006 03:55 PM
PM'd you. I have the bracket
