-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Pegged volt meter (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2667-pegged-volt-meter.html)
Bee Jay 03-08-2001 07:11 AM
Pegged volt meter
I started my car (914 2.0)for the first time in almost a year yesterday. The volt meter pegged, well past 18 volts. It would settle down to 12-14 volts at idle, but would peg whenever I revved the enging. What's up? The car sat idle while it got painted, and I charged the battery the night before.Do I need to replace the alternator.
Bee Jay
jabb 03-08-2001 07:17 AM
Put a Volt meter accross the battery while the car is at idle. Should see 13.2 - 13.5
volts... 14 is on the high side.. Race the
engine see if it jumps to 18 or 19
like the gauge reads if yes I would start by
replacing the Voltage Regulator... Do not
drive the car like this you will boil over the battery with readings that High..
I believe this site has a tech Article on
Troubleshooting Altenator/Charging problems
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Joe Bob 03-08-2001 12:15 PM
If the volts at the battery is good...no more than 13.5, it could be a bad ground on the meter....
Bee Jay 03-08-2001 08:35 PM
Thanks everybody.
After a frantic call to Tom, I learned what a external voltage regulator is. (I'm a Chevy man) I took the regulator out, slapped it silly and cleaned the contacts. It works fine now. I actually took the car out around the block. You should see the grin.
Bee Jay
Joe Bob 03-09-2001 12:42 PM
Soooo....the ground was bad....right?
