Question Catalyst removal
Hello,
I would like to remove the catalyst and the related systems out of my 1975 914/4 2.0 . Would I also need to change the computer of the D-Jetronic fuel injection system? Or is it sufficient to just kick out all catalyst related items?
Thanks in advance.
HM.
Old 03-01-2006, 08:34 AM
I would suggest backdating the exhaust to the 73 or 74 2.0 system. It will improve the HP, and make it last longer (If you use the stainless Heat Exchangers).
You should not have to change the computer. It should work fine.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 03-01-2006, 09:59 AM
blitzer's Avatar
I recently did this. Replaced the exhaust from the heads on back. Runs much better.
914 Restoration
Old 03-01-2006, 01:33 PM
