1.8 mixture help
well the motor is fully reassebled ( except exhaust ) now that it is cranking but not starting i need to know how many turns the mixture and idle screws should be turned out, i had played with them before i pulled the motor trying to get it to run right http://www.pelicanparts.com/ultimate/frown.gif
i smell gas and i have spark so that is not the problem and the timing is close enough to start as well so anybody have any ideas TIA ------------------ scott thacher 75 1.8 under construction 75 under rust (fine german rust) |
| All times are GMT -8. The time now is 05:56 AM. |
