-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Fuse and other problems! (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/274452-fuse-other-problems.html)
Jake Seidel 03-30-2006 05:17 PM
I have a 72 914 1.7 and am missing my fuse box cover inside the car and could use a nice layout of the fuses needed from left to right. My car also is idling at about 2500 what should I dop to fix this? I have tuned the points is there anything else causing this.
Thanks Jake
nine_one_4 03-30-2006 08:24 PM
"67 BMW 1600 w tuned 2002 moter" --> Very cool.
D-Jet Troubleshooting
http://img89.imageshack.us/img89/4739/914booklet8ua.jpg
http://img89.imageshack.us/img89/8605/fuses3kk.jpg
Dave at Pelican Parts 03-31-2006 10:21 AM
The fuse information is also available in the "914 tech specs" section of this very website.
High idle is usually caused by one of two things: Vacuum leaks, or advanced timing. Verify the timing, and then start hunting for vacuum leaks.
--DD
Tobra 04-01-2006 07:25 AM
The lid is the same as for a late model Super Beetle, like $7, or you could get the one with pictures instead of numbers 1-12 for about $40
