Modifying GT valance continues
I tacked the brake ducts on the other day and today I lowered the opening for the oil cooler. Since I will be using the stock bumper with the GT valance I decided to increase the opening by an inch. It's blocked and it's almost ready to glass up.http://forums.pelicanparts.com/uploa...1144800142.jpg http://forums.pelicanparts.com/uploa...1144800168.jpg
What did you use for those ducts? Looks like something borrowed off of something else, just can't place it.
Also, how are you routing that air to the brakes? Maybe a picture from underneath please! Certainly not using Trekkor's Home Depot PVC pipe right? |
Brake ducts courtesy of an aftermaket Ebay Shelby Mustang side scoops which I butchered of course. I am drilling a hole and ducting the air straight up into the open area under the headlight buckets then out the existing hole seen from the inside of the trunk ( area were stuff always falls into ) then will enter the wheelwell in the appropriate spot via a new hole and then to the rotors.
It will look like this in a few months.http://forums.pelicanparts.com/uploa...1144809210.jpg
| All times are GMT -8. The time now is 11:30 PM. |
