minnesota loon's Avatar
Question cylinder 2+3
76 2.0 with crane ignition xr3000. the car runs well when i first start it but shortly begins to miss on 2+3. it seems that i have spark to all cylinders. if i pull the injector wire on 2 it does not change how it runs. could this be injector points? when i drive it accelerates well but wont run at a steady speed without missing.
Old 04-12-2006, 05:07 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Injector points, or the wires to them. Does pulling the #3 wire kill the motor too? If so, I would strongly suspect the injector points or the wiring to them.
--DD
Old 04-12-2006, 07:33 PM
elwood-914's Avatar
Happend to me also....checked the injector points and one was pitted bad.....easy fix. No problems after that.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 04-12-2006, 07:44 PM
Hey! Nice Rack! "Celette"
rich's Avatar
I made a cheap injector wire tester from a couple of small male wire terminals, and a 194 side marker socket and bulb. Connect it to the injector wire and crank the motor. it should light when triggered.
Maybe an injector is sticking.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 04-12-2006, 07:56 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Vacuum leaks if it won't run steady at cruise so its too lean. Check all hoses and the usual suspects.
or pitted points and mis-timed.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 04-12-2006, 08:36 PM
pulled distributor and reset everything. put it back in and it runs a lot better. something must have been loose. thanks for the replies.
Old 04-16-2006, 04:53 PM
