Question Emerg brake removal
How is the emerg brake handle attached to the stud it pivots on? I removed the 13 mm bolt and thought the handle would just slide off. No way! Is there a C clip or something holding this on that I can't see? Thanks for the help.
Old 04-15-2006, 06:07 PM
swl swl is offline
swl's Avatar
Nothing else. The shaft gets rusted and makes it a pita to get off. I used some penetrating oil then put a crow bar between the brake and long. Worked the brake while applying pressure with the crow bar. Took a lot of grunt but it did eventually come off. There is a nylon bushing in there so I wouldn't recommend heat.
Trying to resucitate from a 20 year coma
Old 04-15-2006, 06:21 PM
