Stock Headlight Relay Jumper Question
Hi,
Deciding between H4's or keeping standard bulbs for now.
I noticed the stock factory relay has 4 lugs - 'S', 56, 56a, 56b
The replacement on the PP site has 5 lugs - Probably 30?
Do I need to jumper 30 to 'S' to make it work.
Thanks!
Old 04-20-2006, 01:06 PM
not sure i understand? are you wanting to swap to the H4 conversion headlamps, because your stock bulb plug should just plug right into the H4 bulb. i did the conversion and never changed any relays.
Old 04-22-2006, 12:28 AM
