hitbyastick's Avatar
Send a message via AIM to hitbyastick
What should the voltage be?
Hello,
at idle my voltmeter reads 14 volts at the factory connection for the center console. When I step on the brakes and the stoplights turn on, it goes down to about 12.2 or so. If I then turn on the headlights and all that, it goes down to approximately 10.5. If I add a turnsignal it falls slight below 9.
If I remember correctly, the car has always down this. Although I could be wrong, the car has been sitting for a while. The thing is that the lights don't dim or any of that nature. Faulty gauge? Regulator? Or maybe the alternator is not up to par?
Old 04-20-2006, 07:30 PM
666 666 is offline
666's Avatar
German engineering.
It's fine.
Old 04-20-2006, 08:19 PM
Text me.828-230-0788
Joe Bob's Avatar
30 year old gauges are at best....a wild a$$ guess.
Using a voltmeter/Fluke/Multimeter reading at the terminals a FULLY charged battery.
12.5v at rest
13.0 at idle
13.5-14.5 at 2500 rpms
Anything more than that....you'll end up cooking the battery as the volt regulator is likely bad.
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 04-21-2006, 06:06 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Like the above two guys said, it's normal. I figure the voltmeter is mostly there for entertainment, not to show the health of the charging system.
If it starts behaving differently than it always has in the past, then it could be showing a problem. But otherwise, don't worry about it.
--DD
Old 04-21-2006, 06:24 AM
First good news about this car all year!
Old 04-21-2006, 09:20 AM
Joe Bob's Avatar
The fact that you have a running 914 AND in Germany is a PLUS....
Old 04-21-2006, 10:42 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I agree with Dave. I've installed voltmeters in my 914 and 911 and in both cases they read above 14 volts - with my 914 running close to 16. In the 911, when I turn everything on - radio, fog lights, brights, etc - it goes down to 12V. Don't have that much electrical stuff in the 914, so it does not vary that much.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 04-21-2006, 04:56 PM
do you ever have a hard time getting the car started? thinking mabey you have a corroded ground strap, 9V is an pretty low drop, 14V isn't to bad a lot of newer cars actually charge at about 14.4V. mabey try makeing a new ground for the gauge somewhere close to the gauge and see if that helps. Just a suggestion.
Old 04-22-2006, 12:20 AM
