mejulihn's Avatar
Question Eyeballing the stock oil cooler
How difficult is it to remove the engine tin on the right side of the motor (while it is still in the car) to inspect the top of the stock oil cooler? Despite adding an external oil cooler per Pete Dubler's tech article, my '76 2.0 is still not staying quite as cool as I'd like. Next step is to check that my stock oil cooler is relatively free of debris.
Old 04-09-2001, 04:45 PM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
I know I posted about this in length a while ago, but not sure what the topic of the thread was.
As far as difficult, not really...but can get frustrating.
I am assuming you have fuel injection, so most, if not all of that has to come off. To make it easier, you might want to remove the distributor. Then, you just have to undo all the screws that hold that side of the engine tin down and then wiggle it around until it will come out.
It took me about 30 minutes to an hour to get it off, and it is a little quicker putting it back on once you know what to expect. If I can find the post, I will link to it for you.
Paul
http://www.pelicanparts.com/ultimate/Forum2/HTML/001720.html
Found the old link so posted it...and lookie who it was from
Cheers.
[This message has been edited by paulhagedorn (edited 04-09-2001).]
Old 04-09-2001, 05:00 PM
Post
What are the temps running?????
Old 04-09-2001, 10:20 PM
mejulihn's Avatar
Post
Jake,
Temps are running about 230 degrees.
[This message has been edited by mejulihn (edited 04-10-2001).]
Old 04-10-2001, 11:32 AM
