JW Apostate
trekkor's Avatar
Mini-Paddock
Check out these recent a/x pics!!
I'm the instructor : pointing:
KT
'74 914-6 2.6 SS #746
'01 Boxster
'73 914
Old 05-10-2006, 06:37 PM
JW Apostate
trekkor's Avatar
Steve Nieslony was TTOD :clap:
KT
'01 Boxster
'73 914
Old 05-10-2006, 06:45 PM
Grantsfo's Avatar
I still laugh out loud when I realize my car is in the same class as Steve's.
Grant
2010 Nissan 370z Nismo - Shamu
Old 05-10-2006, 06:51 PM
JW Apostate
trekkor's Avatar
Nathan took 2nd overall
'01 Boxster
'73 914
Old 05-10-2006, 06:53 PM
JW Apostate
trekkor's Avatar
Me!!
I was 4th overall.
Fun stuff...Altissimo!!
'01 Boxster
'73 914
Old 05-10-2006, 07:05 PM
Headrage's Avatar
Trekkor I love the way your car sits so low.
Anything special done to the suspension?
Old 05-10-2006, 07:07 PM
JW Apostate
trekkor's Avatar
Lowered front end with bump steer kit.
200# rear springs on adjustable perches.
The Sweeper Damô makes it look even lower. Woo hoo!!
KT
'01 Boxster
'73 914
Old 05-10-2006, 07:11 PM
So if you happen to whack a cone does it go around or still get caught up in the middle under the car.
When I decide to nail a cone instead of DNFing the cone is a real pain to get out. and usually mangled to ****.
Old 05-11-2006, 02:45 AM
JW Apostate
trekkor's Avatar
They only get hung up if I hit them square on.
Otherwise, they go flying.
KT
'01 Boxster
'73 914
Old 05-11-2006, 06:12 AM
jhadler's Avatar
Trekkor, I think you need to mount a splitter to the air dam, a -sharp- one. That way, you can just slice the cones off at the base, and leave the base still in the box. No penalty! :-)
-Josh2
Old 05-11-2006, 08:37 AM
Oh man you would get one run before ya got sent packing.
NEW SUBJECT:
Hey how many laps is the norm for a open track lapping day. I mean per stint or what ever you call it?
What to expect from the car. I imagine one lap to warm up and figure out where I'm going.
and a lap to cool off (is that needed for 914's)?
How many in the middle?
Old 05-11-2006, 12:13 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Depends mostly on who runs the event. The local (Zone 7) PCA crowd runs 20-minute run groups for their Time Trials, and 15-minute groups for their DEs. Checkered Flag (the outfit My Attorney runs with) give you half-hour sessions.
--DD
Old 05-11-2006, 12:16 PM
jhadler's Avatar
Joe, it all depends on the club, the track, the car, and the driver.
If it's "no problem" you're going to, it's a small track, so I would expect low lap times. Most clubs will hold 20 minute sessions (That's roughly how long your average club race lasts). 20 miutes is a LONG time. You will be exhausted, your tires will be cookin', and hopefully your engine won't be too hot. Watch those temps! If the car (or driver) gets too hot, pull off. Discretion is definitely the better part of valor.
And chances are, that there will be more than one session. But it really depends on the club, and the format. What event is it? PCA, SCCA, NASA?
Did you bleed or flush your brakes recently? If not, DO IT! Put in good, high temp fluid. Drivers that are new to the track will invariably push their brakes harder untill they get comfortable with the higher entry speeds. Autox abuses tires more than anything else. Track events punnish brakes. If you can, try and rig up some brake cooling ducts if you don't already have them. You can even use dryer hose from Home Depot and some zip ties to hold 'em in place. A little ducting goes a long way at the track...
Go have a blast and a half!!
-Josh2
Old 05-11-2006, 12:24 PM
Grantsfo's Avatar
Hey Trekkor here's my MX5 at Shultz. Looks like I should be going 4 wheel'n compared to your car!
Grant
Old 05-11-2006, 12:37 PM
mike_the_man's Avatar
Tekkor, are your rear fenders flared a bit? I've never noticed before, but they look like it. Did you just pull them?
Mike
74 914 2.0L
78 VW Gti
82 VW Rabbit
Old 05-11-2006, 01:08 PM
JW Apostate
trekkor's Avatar
Yes.
I used a hydraulic "Porta-Power" spreader and some lumber to force the fenders out to my liking.
The wood was cut to contour the outer fender well and a 4x4 was up against the inner.
I'm still on 205's, but the fenders were pulled for 225's on 7's.
KT
'01 Boxster
'73 914
Old 05-11-2006, 05:36 PM
JW Apostate
trekkor's Avatar
I'm at a spot where I need to buy tires again.
I may get a pair of 225 Yok A048r's to go along with the two hour old free pair.
KT
'01 Boxster
'73 914
Old 05-11-2006, 07:12 PM
Acox914's Avatar
Send a message via AIM to Acox914
trekk. yuo are SURE the inner fender didnt deflect also??
looks great regardless!
-Aaron
"60% of the time, it works every time"
Old 05-11-2006, 09:55 PM
JW Apostate
trekkor's Avatar
Thanks!
'01 Boxster
'73 914
Old 05-12-2006, 06:18 AM
Put a whipping on some rice and american iron.
No Problem Raceway in Louisianna
the clip is comming down 1000 fot straight into turn 1
the Red Neck racer pulled up on and blew by both cars from behind in turn 14.
Pulled up on them so quickly through the turn before the straight the flag man never waved Blue/yellow.
http://media.putfile.com/100_0381-10
70 MPH through turn 14 and 115 MPH before slight lift to set up for turn 1 .
Old 05-12-2006, 06:52 PM
