Nine Fahrvergnügen , gone kaput
I was tooling down the highway approaching my exit, , when all the power went out.
The alternator belt was shredded and laying on the engine.
The battery was charged enough that it would still turn over.
I checked for spark and there was some
Changed out the coil and no change.
The fuel pump is working and it has pressure.
Looked at the fuses and all seems fine.
When in tow I popped the clutch and notta.
Opened the dizzy and cleaned the terminals up some.
It's a stock 73 1.7 djet setup that always worked well.
Just can't think of what else to check. HELP
Today I put in new plugs and wires. Notta
Replaced the Petronic dizzy with a points type. Notta
Mike came over and did his masterful dizzy work.
Found TDC reset the dizzy, checked dwell, fuel pressure, replaced fuses. Learned much, BUT Notta, notta, notta
I have ECU's I could try, but they are for earlier 1.7. I do have a 45 for a 2.0, again I don't know if that can work.
Any other suggestions
Old 05-06-2006, 05:15 PM
hardflex's Avatar
I would take off the air cleaner and spray starting fluid into the air intake. you said you have spark, so it should fire on the starting fluid, and that would confirm it's a fuel system problem, not an ignition problem.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 05-07-2006, 03:16 AM
Tryed that Hardflex. Looks like it's electrical, but thanks, Joe
Old 05-07-2006, 07:39 AM
914 Geek
What do you mean by "has some spark"? It has a weak pathetic spark, or it has a spark but not all of the time--or just "yes it has spark"?
It needs fuel, air, and spark. It also needs about the right amount of fuel, and the spark in some vague approximation of the right time.
Check the compression to tell if you've got air going in. Check for fuel going into the engine itself (not just into the fuel system creating pressure). Re-check for a good fat happy spark. Re-re check the static timing; it should be close to TDC.
If all of that checks out, you've got a fuel quantity problem.
--DD
Old 05-07-2006, 07:57 AM
trojanman's Avatar
joe,
is the starter getting juice? have you hooked up a meter to see how many volts you are getting at the starter?
Old 05-07-2006, 09:39 AM
It turns over fine Greg. Is that what you mean?
Old 05-07-2006, 12:35 PM
Swap coils if you have one. If not. get a new blue coil. Does wonders.
Old 05-10-2006, 03:42 PM
SirAndy's Avatar
Re: No more farficnugan, gone kaput
maybe if you speeelt it right ...
Fahrvergnügen kaputt
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 05-11-2006, 09:46 AM
Re: Re: No more farficnugan, gone kaput
Andy
How's that Jerry!!
Still haven't done the compression test but am a proud owner of a Compression tester now. Sure miss the little bugger she was my only real release during my busy season. Now maybe i''ll drive my 78 Bronco over a couple little cars and get some different fun. Almost for got about the beast.
Still up for suggestions.
Old 05-11-2006, 09:08 PM
Acox914's Avatar
Send a message via AIM to Acox914
trigger points?
-Aaron
"60% of the time, it works every time"
Old 05-11-2006, 09:33 PM
Mike Ginter
gint's Avatar
Re: Re: Re: No more farficnugan, gone kaput
How's that Jerry!!
You still need to pull all of the injectors and check them for function and pattern Joe.
Ginter's 914 stuff
Old 05-12-2006, 04:25 AM
