Type 4 Unleashed's Avatar
Collecting Rods
Rods, are made by Lentz, one on the right, is 6.200" center to center, 1.888" jrl dia., .927" (23.6mm) piston pin, EDM oiling 3/8 bolts, 557g's, out side dia. of the big end is 3.150"
Left. 6.300" center to center, 1.771" jrl dia., .927" piston pin, no EDM oiling, 5/16 bolts, 465g's, out side dia of the big end is 2.895"
I'am currently running a 77mm stroker, with rabbit jrl's (1.805") rabbit rods with a center to center of 5.355"
I, intend to go to a 86mm or possibly even an 88mm crank, and I've been looking for a rod that will meet clearance issues, without costing a Kidney or a big left nut, like some one else, who has been willing to sell or trade to upgrade his car
These rods, will need some mods to work, but the 1.771 jrl rod is only .034" smaller than the jrl dia. that I am currently running, so I may try it.
Richard
Old 05-13-2006, 12:48 AM
Twystd1's Avatar
Can you reverse the bolts on a Lentz rod?
Clayton
I probably know less than you.....
Old 05-13-2006, 06:41 AM
Call Jim Durish at Cunningham Rods in Gardena. They can make you whatever you need. (310) 538 0605
The Cap'n
Old 05-13-2006, 10:54 AM
Acox914's Avatar
Send a message via AIM to Acox914
i still have my left nut for trade of a 3.6
kidney too!
nice work richard!
-Aaron
"60% of the time, it works every time"
Old 05-13-2006, 11:51 AM
Clayton
The question is will it hold together after I DO.
Richard
Old 05-14-2006, 12:10 AM
