911 20mm sway bar
Thats what someone wrote on my bar. But looking at other swaybars that fit on the 914 this one doesn't look anything close. There are no end links. just the bar slides into a rubber bushing mounted right on the lower A arm. The rubber is split and the bar has a little bit of wiggle in it. Anyone ever see anything like this?
Old 05-13-2006, 11:43 AM
Old 05-13-2006, 12:23 PM
Burn the fire.
Brando's Avatar
that's because it is a 911 swaybar. The 914 and 911 (up until 1989) have an interchangable front suspension.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-13-2006, 12:58 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
That looks like a stock "under-body" 911 sway bar. They went from "through-body" (like the 914 front bar) to "under-body" (this type) in about 74.
Through-body is supposed to maintain better geometry, while the under-body type is cheaper and easier for the manufacturer to mount on the car.
--DD
Old 05-13-2006, 01:48 PM
does anyone make polyurethane bushings for this type of setup? I'm not sure I can put on a 914 style bar since my front end is cut up for the V8 conversion.
Old 05-13-2006, 02:06 PM
Acox914's Avatar
Send a message via AIM to Acox914
the stock thru body bar goes UNDER your gas tank. where do your water lines come thru?
-Aaron
"60% of the time, it works every time"
Old 05-13-2006, 07:37 PM
in the first pic you can see the water line, it goes just under the steering rack and come out infront of the gas tank.
Old 05-13-2006, 07:44 PM
Acox914's Avatar
a thru body sway would work fine, and offers adjustability.
have you checked if pelican offers replacement poly bushings for the underbody 911 bars?
-Aaron
Old 05-13-2006, 07:45 PM
