-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Carb linkage. different setups (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/282634-carb-linkage-different-setups.html)
hammy 05-13-2006 03:56 PM
I've noticed some carb linkage setups have the linkage towards the back and then some have it towards the front, with the accel. cable coming from between the firewall and engine.
Is it a matter of preference or is there something more ?
Joe Bob 05-13-2006 03:59 PM
Differing linkage, setup, parts, preferences different carbs.....chose one.
hammy 05-13-2006 04:14 PM
Ok, well i'm an idiot...
I'm not really sure how the linkage on this engine is supposed to go. dual weber 40s...
This is what I got.....
http://forums.pelicanparts.com/uploa...1147562025.jpg http://forums.pelicanparts.com/uploa...1147562034.jpg
Joe Bob 05-13-2006 04:25 PM
Well you need a support mount/part that mounts to the engine so that the throttle cable shaft can be anchored to and then the cable can pull the bar.
hammy 05-13-2006 05:03 PM
Is the bracket in the first pic for routing the cable too?
also I assume the cable support mount you mention can be home fabricated.. ?
Joe Bob 05-13-2006 05:16 PM
Sorry, missed the bracket in the pic.....I assume the cable end is threaded?
You CAN use a nut on one side with a washer, push it thru a hole in the mount, washer and nut on the OTHER side, tighten and that is where you then decide where to position the arm on the linkage. The arm can move360 degrees in most cases.
It's trial and error on the correct setup.
Joe Sharp 05-13-2006 05:31 PM
Zack: This is the set-up that got Linda 49MPG.
Joe
http://forums.pelicanparts.com/uploa...1147566654.jpg
Acox914 05-13-2006 06:41 PM
zack,
get a CBperformance linkage or a triad....
that bracket that you pictured is wortless on a 914
So.Cal.914 05-13-2006 06:58 PM
I don't see any end pivots that usually mount to the carbs to hold the throttle bar in place, maybe you just didn't picture them. If not you
will need to look into that.
hammy 05-13-2006 11:40 PM
Thanks guys...
I'm using a new stock throttle cable..
Joe, 49mpg is amazing. I told my dad about that and his jaw dropped.
What's the difference between this linkage and a CB or triad?
The end pivots are hanging on the carbs so they weren't pictured :)
Joe Sharp 05-14-2006 06:38 AM
Zack: Linda's is the CB.
Joe
