Spin'n Wheel's Avatar
Angry FI challenge
I got T-shooting Q: about my NARP.
On a 2.0 motor right around the Dist. are a bunch of connections.
1 (or 2) coming out of the dist. itself. Those are obvious and go to the coil. 2 come from relay panel harness: Grn w/Red stripe I am guessing is the Oil presure sensor (BTW where do you find that funky rubber gromet?) & a wht. wire. Where does the white go?
Then there is a white coming out of the FI harnes, Im guessing that goes to the temp sensor mounted on the plenum leg(thermoswitch?).
Last is the red wire coming from the Aux air reg. Where the heck does that go, as it seems Im out of connections..?!!
Old 05-14-2006, 12:14 PM
bowlsby's Avatar
2 come from relay panel harness: Grn w/Red stripe I am guessing is the Oil presure sensor -->Yep.
& a wht. wire. Where does the white go?--> to the red wire on the AAR
Then there is a white coming out of the FI harnes, Im guessing that goes to the temp sensor mounted on the plenum leg(thermoswitch?). --> Yep again.
Last is the red wire coming from the Aux air reg. Where the heck does that go...--> see above.
Old 05-14-2006, 02:38 PM
