-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   5 lug 914 coil spring front end (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/282793-5-lug-914-coil-spring-front-end.html)
SirAndy 05-14-2006 05:38 PM
Originally posted by djpateman
This just does not make sense.
i agree!
i think your suspension might bottom out. if the car is lowered, did you install the bump steer spacers?
if the car is *not* lowered and you got the stock 914 torsion bars, it should feel like a caddy el dorado ...
if it doesn't, something is wrong with your suspension.
i think you're looking in the wrong place ...
:cool: Andy
Acox914 05-14-2006 05:47 PM
i agree also...
usually the stock is TOOOOO soft.
i bet you oversteer like crazy with the 200's....
drive-ability 05-14-2006 05:57 PM
I need to have someone who knows what there doing have a look at the car. I drive it easy with an occasional hard straight run. I am sure there is a club member close enough to have a look. I just don't know enough about these cars. I don't want anyone to do it for free, but do wish to get connected with the right person. I am sure theres a lot more that can be done to get the car to run better on the road.
Acox914 05-14-2006 06:43 PM
id be over there in a heartbeat :)
see if joe sharp or one of the OC guys can take it for a drive :)
drive-ability 05-14-2006 06:52 PM
That would be so helpful, sometimes you spend so much time working on a project you loose the ability to analyze issues objectively. http://www.pelicanparts.com/support/smileys/explode.gif
byndbad914 05-15-2006 06:23 PM
Can you really make a 914 ride like a Caddy in the first place? I remember my bone-stock, well-used 914s riding pretty rough - they are basically little soapbox cars, which is why I like 'em.
IIRC, the 17mm stock bars are equivalent to a spring less than 200lb/in, which is pretty soft to begin with. If you want to go coil-over, maybe consider the yellow RSR struts instead of the stock green RSRs.
The valving is set up for a 220/100 and the 220 is rebound, 100 compression (stock RSR is something like 162/162). Means that there is little control of compression - lets the spring do its job - and because they expect people to run stiff springs, the larger rebound helps control the spring expansion over dips (don't quote me on this part - ask Bilstein for confirmation - what I remember after talking to a tech about mine). Maybe with a soft spring, you would have a swoopy/swishy ride like a Caddy on compression, but over bumps/dips, it might carry the wheel. Then you would just find a really low-rate spring for it.
It is funny because I am just the opposite with my V8 car - I have 300 front and 450 rear springs and am planning to up the fronts - car rides like a lumber wagon but good for the track.
drive-ability 05-15-2006 07:36 PM
I have seen your car and that is a real track monster. I am just a cruiser and use it as a daily driver. I am going to go with some softer rear springs in a couple of weeks and see how that feels. I am also going to see about getting some club members to drive the car and chime in.
http://www.pelicanparts.com/support/smileys/wat3.gif
I really like this set-up by "Dozer", I haven't herd from him in a long time but it's a nice setup.
http://hypertec.ws/todd_porsche/photos/strutbody/strutbody-Pages/Image16.html
Acox914 05-15-2006 07:59 PM
wow. airbags on a teener.... wonders never cease.....
oh... and you will need spacers to clear that airbag... :p
byndbad914 05-15-2006 08:31 PM
I had kidded about bagging my car a while back with this photo where I wedged a wheel in while it was on the ground at the chassis shop - I didn't think someone would actually do it :)
http://forums.pelicanparts.com/uploa...1147749994.jpg
Be happy you can drive yours :p Mine is moving along but the little things take awhile to piece in - and had some trouble with a machine shop I was going to use for some machining - cost me 1-1/2 weeks while they yanked me around and f'd up what I ended up doing in a day this weekend :mad: Sucks to have a car sit at a shop for almost 2 weeks because the chassis guy can't start the suspension without those pieces http://www.pelicanparts.com/support/smileys/shake.gif
AJ said he would hit it hard this week and try to catch me up tho'
drive-ability 05-15-2006 09:02 PM
byndbad914,
Your car is one of a kind for sure, man that thing will just fly around the track when you get it sorted out. That would be my first choice if I had the extra cash to build one.
Aaron,
I just may do it! The manufacture makes them with a 4" diameter.
bondodust 05-15-2006 10:59 PM
Real seats (if you're not really tall) can make a world of difference. I put MR2 seats in a 914 that was uncomfortable to drive in for more than 30 minutes... It made all the difference in the world. It went from a harsh ride to a nice comfortable ride, and all I changed was the butt interface. You might also want to consider higher profile tires if you're running a super low profile now.
drive-ability 05-15-2006 11:20 PM
Excellent suggestion, My seats are not stock 914 but cheep knock off racing seats. They have some pad but aren't at all like seats you would find in a normal car. :)
djpateman 05-16-2006 12:46 PM
I thought it interesting that a friend preferred his 914 over the 911 for cross-country tours. The seat was a big part of that.
A couple inches of foam is much cheaper that a coil-over front suspension, and easier to test.
The flex in the sidewalls of tires is designed to provide a lot of the ride compliance. Short, verticle and stiff sidewalls will make for a harsh ride, but gives good steering response.
