1974 1.8 Starter Removal
Anybody got any suggestions for removing the top starter flange nut. Haynes says is accessible from the engine compartment, it is not. I can't get a 17mm open end wrench or a socket on it, love to hear from somebody that has done this before. By the way it's a 1974 stock 1.8.
Old 05-14-2006, 01:35 PM
SirAndy's Avatar
Re: 1974 1.8 Starter Removal
never had any problems with that nut. remove the air-filter for easier access. open end wrench will do just fine ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 05-14-2006, 02:33 PM
Thanks Andy. When I first looked it, didn't look like there is any access from the engine compartment, I'll take another look.
Old 05-14-2006, 02:42 PM
djpateman's Avatar
It is not a 17mm, I believe it is a 15mm, only used in the one place. The bolt head is held by the starter.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-14-2006, 05:14 PM
Control Group
Tobra's Avatar
You may have to put a socket with a looong extension on the top bolt by the starter. I changed mine, and the old starter had a raised area that prevented the bolt head from turning. New starter(Upgrade to 911, 1.5 hp unit)did not have this.
Old 05-15-2006, 05:35 AM
