side output shaft seal
is it easy to replace the side output shaft seal with the transmission in the car. Mine seems to be leaking
Yes. It's really easy. Get new seals before you start the job. Don't forget to smear the shaft/seal mating surface with gear oil before installing the seal.
do not scratch the bore when you pull the old ones... or it will leak. use a ring of same OD to tap the new seal in :)
Thanks guys
| All times are GMT -8. The time now is 03:58 AM. |
