side output shaft seal
is it easy to replace the side output shaft seal with the transmission in the car. Mine seems to be leaking
Old 05-15-2006, 07:11 PM
Mike Ginter
gint's Avatar
Yes. It's really easy. Get new seals before you start the job. Don't forget to smear the shaft/seal mating surface with gear oil before installing the seal.
Ginter's 914 stuff
Old 05-15-2006, 08:25 PM
Acox914's Avatar
Send a message via AIM to Acox914
do not scratch the bore when you pull the old ones... or it will leak. use a ring of same OD to tap the new seal in
-Aaron
"60% of the time, it works every time"
Old 05-15-2006, 08:30 PM
Thanks guys
Old 05-16-2006, 05:54 AM
