Excessive Heat in Front Wheel
I noticed lately I am getting excessive heat out of my front driver side wheel from simple running down a few blocks for a cup of coffee and back.
The car rolls fine and evenly in neutral. My tire isn't rubbing at all. The heat seems to come from the wheel and not the rotor but... Is it my front caliper or wheel bearings? Sway bar problem? Bad shock? The car rolls straight. I have got a real bad back so I only got one shot at this.
Steve Visit My Blog: http://fromsteve.blogspot.com 1974 914/4 2.0 2006 Hummer H3 2005 Dakota |
get any shimmy in the front end at speed? maybe the caliper is sticking?
Usually means front pads are dragging. Jack it up and see if the wheel turns freely. If not, pull the pads and "exercise" the pistons by applying the pedal with blocks of wood a little thinner than the pads placed between the caliper and the rotor. Carefully pry the pistons back in and repeat several times. If that doesn't solve the problem, time for a rebuilt caliper.
Typically this is a result of the caliper sticking, and dragging brakes, as has been suggested. However, if the heat is more in the tire than the rim or the brakes it could be the belts shifting within the tire. You can sometimes see the tire bulging in funny ways when this happens. You won't notice the drag from the brakes if you spin the tire off of the ground, but you should see the tire wobble.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
