-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Rear Trunk Lid Alignment (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/285646-rear-trunk-lid-alignment.html)
addwestern 05-30-2006 11:15 AM
Hi All-
I've been figthing an alignment problem on my rear decklid. I finally got the replacement shoulder bolt and the trunk shocks are on the way.
Currently, my configuration is one torsion bar on the right side until I get the new shocks in.
I've been having difficulty getting the decklid aligned properly to latch nicely. It seems like when I do get it correct, it's too far back and the engine grill strikes the decklid. This is a real PITA. Much swearing ensued....
If anyone has any good tips, I'd appreciate it.
Thanks,
Nate
nine_one_4 05-30-2006 11:50 AM
Have you considered the adjustable pivot kit from JWest Engineering?
http://www.jwesteng.com/porsche/pivot.htm
addwestern 05-30-2006 12:08 PM
Yes, I have.
It seems like I should be able to get it with the stock hinges though. I don't think I'm far off as I can manually shift the lid if I can leave the deck bolts a little loose.
Dave at Pelican Parts 05-30-2006 02:55 PM
Check the L-brackets that hold the engine lid onto the firewall. They tend to crack at the bend of the L, which lets the lid move back and interfere with the rear deck lid.
--DD
