Banned
Is 400 ft. lbs. of torque enough to remove the axle nuts?
I found this 3/4" electric impact wrench at Harbor Freight for $90. It's rated at 400 ft. lbs. and the price is right for a tool I'll probably only use a few times.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92651
Old 06-17-2006, 11:16 PM
RETIRED
Joe Bob's Avatar
Probably...don't expect a HF tool to last long.
What's the matter with a 1/2 breaker bar, a cheater pipe over the end and a fat guy stepping on it?
Only time you would NEED a impact is if the car is in the air and there is no drive train......
2012 ML350 3.0 Turbo Diesel
Old 06-18-2006, 09:52 AM
Banned
Yup, that's what I got.
Old 06-18-2006, 10:38 AM
Acox914's Avatar
Send a message via AIM to Acox914
hey alfred...
400 should be enough... start soaking it with penetraing oil.... my 240 lb 1/2 inch inpact couldnt budge them... but a 6 foot pipe worked great....
-Aaron
"60% of the time, it works every time"
Old 06-18-2006, 11:53 AM
Acox914's Avatar
and what is the engine hoist for?
-Aaron
Headrage's Avatar
Holds the car up...
Old 06-18-2006, 12:08 PM
RETIRED
Joe Bob's Avatar
Sounds Mickey Mouse....But I have used a set of vice grips on the axle to keep it from turning enuff to break the nut loose.
Old 06-18-2006, 12:20 PM
i borrowed a elect impact a few days ago (craftsman brand). i don't know what the rating was. i had sprayed the nuts a few times over a week with aero kroil. they ran off in nothing flat. i was stunned!! no bolting up the wheel to some brace/stopping device and a breaker bar with some monster piece of extension pipe. buy a 30mm impact socket and just check your local tool rental bizs for the impact.
k
here? not so much i think. high five!!!
Old 06-18-2006, 12:41 PM
Banned
Just something I'm trying. If I can make it work, I'll post some pics.
Old 06-18-2006, 04:01 PM
Banned
k
Thanks for the advice. Anyone know where I can get aerokroil in Canada? I think Walmart has PBlaster.
Old 06-18-2006, 04:06 PM
www.kanolabs.com. i bought it directly from kano labs the first time. pb blaster is excellent too. i might add i didn't resort to any torch to heat the nuts up.
k
Old 06-18-2006, 09:23 PM
Aren't those impact wrenches great. I didn't have a compressor or impact wrenches for many years. Finally bought them a few years ago and I'm still amazed at the crap I went through before that...
'73 2.0 -- Yellow
Old 06-21-2006, 05:57 PM
There are also those rear brake things. You know , brakes
Old 06-21-2006, 08:37 PM
