914 914 is offline
914's Avatar
Porsche Crest 914-6 Whining Noise From Rear Area
The noise starts about at 10 Mph,I put it in Neutral
and coast whining noise still there,Slow under 10 Mph
then it stops,Rear wheel bearing,Cv joint ??
Thanks For The Help!! 914
Old 06-03-2006, 10:28 PM
Member w/ Title Problems
Jason Porter's Avatar
A bearing would be my first thing to check, and make sure you've got grease in your CV's, as that only helps extend the life of everything connected to them...
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 06-04-2006, 08:49 PM
djpateman's Avatar
It could also be worn out brake pads. I have a brake pad where the caliper was seized to the point that the metal back was worn through, and the piston was wearing on the brake rotor. I'm sure it made a similar noise.
However, every part of the rotating assembly there is suspect. From stones caught between the rotor and the caliper to the splash shield rubbing on the rotor. Bad bearings (wheel and tranny), bad CV joints. There is a lot to inspect.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 06-05-2006, 08:02 AM
have you checked to make sure the gear box has the sufficient ammount of lube?
k
here? not so much i think. high five!!!
Old 06-15-2006, 08:04 AM
914 914 is offline
914's Avatar
The noise stopped for now,the previous owner said it comes and goes,The cv joints were packed at years ago.The car was only driven like 6K in 12 years.I thought breaks too but there is alot
of pad. Rear wheel bearings or transmission bearings may be the cause,Any Ideas...
Thanks For The Help Fellow Teeners,
914
Old 06-15-2006, 07:49 PM
