kb piston arrow
I can't find an arrow pointing to the flywheel on my new KB 96 mm pistons from P.P. Can you put them in upside down? Or doesn't it matter with this brand. Also the Hastings ring they came with tell you to check the gap on the top ring. Has anyone had a problem with the gap being to small?
Old 07-03-2006, 04:37 PM
I built a 96 before, but mine had a place for the valves cut out.
Measure from the wrist pin to the skirt and see what the difference in measurement is. That should tell you what side the piston rocks to, thus what side is "forward"
Old 07-03-2006, 11:21 PM
