Hello I am a 911 owner thinking of adding a 914 to the stable so my knowledge of 914's is minimal. My question is do all years of 914 run on unleaded fuel? If not what years do? Thanks
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
N-Gruppe doesn't exist
yes
and if you dont change the compression you can run regular unleaded if you like too.
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Thanks................I probably only have 1,000 more questions to go!
Actually, early 1.7s ('70-'72) need premium (91 octane, at least). They have higher compression than the '73 1.7, and MUCH higher compression than the 1.8s.
In general, any engine with aluminum heads (which probably includes all road-going Porsches) will work with unleaded gas. Many older iron-headed engines had their valve seats cut straight into the head, and the soft-ish iron needed the lead to keep the seats intact. Aluminum is so soft it would die very quickly without hardened valve seat inserts, so all such engines have the inserts, and thus work with unleaded gas. |
Banned
Here's the information from the Haynes manual. IIRC, 91 RON corresponds to 87 AKI that you find on gas pumps in North America.
From Wikipedia: Quote:
