brake line questions
I am in the process of performing the 320i caliper conversion. Does anybody have the following information.
1. stock brake tubing size (6mm/10mm - or can I use english sizes)
2. stock brake line nut size (OD & pitch)
3. BMW 320i brake caliper nut requirements (OD & pitch)
Would measure myself, but I do not have access to the car now and would like to get some parts on order.
Also, I am planning on using 90/10 copper-nickel tubing. Does anyone know of a supplier for this. Only place I have found is www.fedhillusa.com
Thank you
Old 07-19-2006, 07:27 AM
djpateman's Avatar
Stock nut is 10mm x 1mm, BMW should be the same. Don't know why you need other than the standard European brake lines.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-19-2006, 10:21 AM
