-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Used Tech Info Kill Switch and Tach Jumps (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/296309-used-tech-info-kill-switch-tach-jumps.html)
RSBob 07-31-2006 02:59 PM
I followed the instructions and the switch works beautifully. The tach also works but now jumps intermittently - never a problem before. The engine has no cutout or other effects relating to the jumping tach. Loose ground the cuprit? Bad switch (a $2.50 item from local autoparts store).
I have a similar setup on the 911 with no issues.
I will play with the wires tonight and make sure all the connections are snug. I do not own an ampmeter (I have destroyed two)
RSBob 08-01-2006 12:14 PM
Update - all wires and connections are sound, BUT when jamming the rocker switch into my secret location, one of the male spades wiggles just a bit. Will replace the switch tonight and jam it back with less enthusiasm. Film at 11:00.
