Bosch P/N for Ignition Rotor?
I have 2 ignition rotors. Bosch P/N 04 038, which I got from Pelican, and Bosch P/N 04 033, which I got from another supplier. Which is the correct part for the 1973-2.0L application?
TIA |
Banned
Is there a second p/n on them? Go here and then open the 914 parts catalog and go to page 264 to see the Bosch part numbers. You may have to check the part number on your distributor to match it with the proper rotor in the catalog.
Re: Bosch P/N for Ignition Rotor?
The stock rotor was 5800rpm rev-limiting was it not? 04030 aka 1 234 332 207.
