Can I connect it directly ?
I just want to make sure. My 74 1.8 doesn't have any hose connected to the oil breather beside the oil filling cap. The hole on the air intake pipe where it should go has been blocked. Can I just connect a hose between those 2 or is there some kind of valve in the T shaped metal tube that should connect them ? Thanks
Check out Pete Klager's hose diagrams on the PP home page. It looks like a direct fit on the 1.8 L engine.
Thanks. There seem to be a T shaped tube that also connect to the EGR valve. Does anyone has any idea where I can find one fo these ?
| All times are GMT -8. The time now is 06:07 AM. |
