-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   1.8L question???? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2981-1-8l-question.html)
Va914 05-07-2001 05:39 PM
1.8L question????
How can I fab or where can I buy the little 90 deg elbow connected to the aux air valve?
What sensor is connected on the bottom of the intake plenum? I can see a bosch type connecter attached to somthing??
[This message has been edited by Va914 (edited 05-08-2001).]
Dave at Pelican Parts 05-08-2001 09:00 AM
No idea on the elbow. Do you really need it? I don't remember if there's anything in the way or not...
The thermo-time switch (controls the cold-start valve) is down low on the plenum. I think it's below the CSV.
--DD
Va914 05-08-2001 03:51 PM
Thanks, I thought it might be the thermo ****ch. The 1.8L isn't starting to well cold. The cold start valve isn't working?
Thanks again
Dave at Pelican Parts 05-08-2001 05:32 PM
I think the CSV is only supposed to operate when the engine is VERY cold (like <40F or thereabouts--might have been 50F, but I think it was 40F) and while the starter is cranking.
Not sure what it could be offhand. Look through the Haynes FI chapter for some diagnostics on the L-jet system.
--DD
