Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
Post 4 cylender compared to a 6
I Was wondering how big a 914/4 engine needs to be made to be equal in size or just a little bigger than a 914/6 engine. I am going to build up the old 4 instead of doing the 6 conversion
Sweet Blue 72' 914
Check it out at
http://www.geocities.com/eat_um_up/914.html
Old 05-11-2001, 03:19 PM
mejulihn's Avatar
Post
Well it sort of depends on what you really mean. The '73-'76 4-cylinder 2.0 engine has the same displacement as the original 6-cylinder motor (also 2.0 liter). However, the horse power and the performance curve for the -6 runs higher, so the difference is very noticeable. For the equivalent "seat-of-your-pants" feel, maybe someone who has a "Big 4" can give you some direction here.
Old 05-11-2001, 04:00 PM
Eat-um-up's Avatar
Post
yeah thats wha im looking for. ow big wouldi have to go to get the same feeling of being put in my seat.
Sweet Blue 72' 914
Check it out at
Old 05-11-2001, 04:07 PM
DF DF is offline
Cool
A mildly built 2.1 (96mmp&c)with webcam,P&P,tweaked injection, fully balanced, 8.5/1cr should get you close.
120h.p.
130lbs torque.
I'ts a shame we have to do so much to compete to a six. But the motors are much cheaper to hypo compared to a six.
Old 05-11-2001, 06:35 PM
Post
A 2.3 (2270) will smoke most 6 cylinder beast of equal or slightly larger size. The torque is so great that breaking traction beccomes a problem.
Old 05-11-2001, 07:13 PM
John Rogers's Avatar
Post
The cost is just about the same if both are done right. By that I mean the big 4 has to be dry sumped and have a front oil cooler and will probably be 2.5l or bigger to out run a 2.2l six. A 3l six conversion in San Diego is about 10 to 12 thousand including the engine. To build my 2.8l four it cost about $6000 and a big part of that is the head work and other machining on the four and the six I mentioned is relativly stock. I think I do have more torque out of corners and can do pretty well till I get to 120MPH or so.
Old 05-11-2001, 07:57 PM
