-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   what fuse should i piggyback to run wiper pump? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/301783-what-fuse-should-i-piggyback-run-wiper-pump.html)
Acox914 08-31-2006 11:14 AM
need to pick up a fused + to run the wiper pump. which fuse should i tap? i have no stereo or heater stuffs, if that makes a difference in which could handle the extra load
AA
bd1308 08-31-2006 12:05 PM
sicne that washer fluid pump needs so many amps, I would run a #0 wire from the battery to your pump.
What exactly is a wiper pump? I hope you didnt backdate to vacuum operated wipers...a RARE option indeed.
John Rogers 08-31-2006 12:33 PM
One with switched power?
spoke 08-31-2006 12:42 PM
Pick one with an 8 amp fuse and install a larger amperage fuse to account for the extra current of the motor.
Spoke
Acox914 08-31-2006 03:40 PM
924 wiper switch facilitates a pump (i have a space saver tire... so no pressureized tank for me :)
thanks spoke. ill pick one with an 8
Kevin Powers 09-01-2006 04:33 AM
i suggest the one for the cig lighter. high amperage and rarely used.
k
