Question Brake pad "spreader" springs
I'm trying to finish up my front brake job, and both of the "+" shaped pad spreader springs are rusted completely through. I've tried to order them through PP, but I'm being told that they are NLA.
My obvious question is ---- do I really need these things? I'm not really looking forward to trying to track down servicable used ones.
Would sure appreciate any guidance.
Thanks in advance,
Howard Henneman
Old 05-16-2001, 05:07 PM
John Rogers's Avatar
Post
Yes, I'd use them to prevent the pads from flopping around. Try a salvage yard and if they have no 914s a VW 411 might also still have the front calipers installed. Good luck
Old 05-18-2001, 08:06 AM
Smile
Several years ago, I ordered these spreaders thru the local VW Dealership using the part number 311 615 269. The cost was not too bad.
Old 05-18-2001, 04:36 PM
Post
Guys, thanks for the advice. I'll try to get them from a local VW dealer. If that doesn't work, I guess that I'll try to re-use the old ones ------ better than nothing.
Howard
Old 05-18-2001, 07:57 PM
