Question short shift kits
can anyone here tell me the pros and cons of the short shift kits out there for a 73 2.0
i am leaning towards the WELTMEISTER SHORT SHIFT KIT
but wanted some feed back before putting it into my car
Old 05-30-2001, 07:37 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
You should save your money on the shift kit and replace ALL the bushing in the shift linkage. putting a SSkit in will only making Balky shifting worst. Steve
Old 05-30-2001, 07:43 AM
Exclamation
I was going to put in the short shift kit AFTER replacing the bushings and rebuilding the tranny
Old 05-30-2001, 08:07 AM
Send a message via AIM to kena
Thumbs down
PO installed one in my 76 2.0 and it sucks.
Reduced throw(leverage) makes it hard to get into 1st and increases the frequency of missed shifts. I would not recommend it. I am going to reinstall the factory shifter and check all the bushings. Put your money into something else.
Red face
Thanks for the response
was it the WELTMEISTER you installed
Old 05-30-2001, 08:28 AM
Post
I may be the odd man out on this topic, but I like my short shift kit. I used the kit for a year or so before changing the worn shift bushings. Once I changed the bushings, I liked it even better. As far as missing shifts, practice makes "better". Keep in mind that our tranny was not built for speed shifting anyway. I just like the fact that I don't have to lean forward now to engage 2nd and fourth gears. Good luck!
Pritchard
BTW: the installation is fairly easy.
Old 05-30-2001, 10:01 AM
Post
Hello 914kit,
I installed the Weltmiester short shift kit and the lockout spring kit on my 1973 1.7L about three years ago. I am very happy with both units. Shifting is clean and precise. I did not istall the units for fast, hard shifting, but rather to ELIMINATE nicking reverse going to second, and reduce the long distance throw into each gear. You will have to remember though, the shorter stick does require slightly more effort to shift (Especially first gear). If you are careful following the directions of both units (Kits), and as others have said on this forum about having the rest of the transmission in good condition, I think you will enjoy their benefits. Regards.
Old 05-30-2001, 12:02 PM
DF DF is offline
Post
The weltmeister is fine. I have it and would rec a weighted shift knob because you lose leverage but I like the short throw. Just make sure your bushings are good and shifter is adj properly so as not to hit clutch cable tube.
Old 05-30-2001, 05:44 PM
Qmodo's Avatar
Post
I am tracking my car and was hoping the short shift kit would help me with my need for quicker and cleaner shifts on the track. In fact I mashed 1st gear two weeks ago and was going to have the shop put in a short shift kit since they were working on the tranny but apparently I am missing some adjustment parts where the gearshift linkage enters the transmission so until we get those parts the shop wont do it.
Obviously there is some debate here whether or not installing this kit is advantageous.
It would be good to know if any of you fellows with the short shift kit track your car and if that has made a difference.
Martin
Old 05-30-2001, 07:42 PM
Post
Has anyone ever tried a cable shift, especially with on a tail shifter?
Old 05-30-2001, 09:38 PM
