Post 914 Door Handle Removal
Car is '74 1.8...problem removing outside door handle. Haynes manual says: from inside the door panel remove the socket headed bolt.
Question is: is this an "allen" socket and if so...what size?
Old 06-04-2001, 05:13 AM
ShawnO
Guest
Posts: n/a
Post
It is an allen head. Don't remember what size though, pretty common.
Old 06-04-2001, 07:14 AM
Post
Didn't receive any message!!
Old 06-04-2001, 07:38 AM
Post
Thanks, Shawn...got it now!!
Old 06-04-2001, 07:39 AM
914 Geek
Porsche Crest
The screw is an M6 screw, and I think those take a 5mm Allen key. Try the 5mm one, if you can't get it in at all (not even close), then try the 4mm one. Don't start with 4mm, if it's really 5 you can strip the head, which will make you very unhappy....
--DD
Old 06-04-2001, 02:27 PM
