rich running 912E
What do I need to look for/adjust for the mixture control as it runs too rich and smells of unburnt gas at idle. It seems rich from startup cold to warm running - CHT sensor or? I do not think the cold start valve is leaking - or just injectors that do not atomize fuel properly.
Had been sitting for a while, and going through it all - fresh tune-up and valve adj.
Ideas?
Old 11-16-2006, 12:10 PM
no ideas?
39 views and not a solid response - has this happened to any of you?
Old 11-20-2006, 11:17 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
I would say its the CHT as that controls the AFR when cold to hot. Swap in a new one as they are cheap.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 11-21-2006, 08:14 PM
I'd run a bottle of Techron through it before putzing with the injection parts, if it ran well before it sat.
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 11-22-2006, 09:57 AM
I will be checking the cht sensor and the aft, and am running techron and drygas through it to try and clean it up. I have no idea how it ran before I got it, or the service history. It has 165k on it - seems to be well taken care of.
Old 11-22-2006, 10:04 AM
Bleyseng's Avatar
use a Ohm meter to check the CHT cold then stick it in boiling water to check its hot readings. Its a 012 number so it should be the same as the 914 2.0l one ohm wise. See Brad Anders djet page or Ratwell's bus website for the speciific numbers. Ratwells site is Ljet specific so that might also help more.
www.914Club.com
My Gallery Page
Old 11-23-2006, 11:56 AM
