What Bilstein shock should I use?
Heres the shimmy,
I'm wonder what those of you have done shock wise with comperable components. I'm going for a streetable/agreesive suspesion. Bistein heavy duty or sport? My 914 completed will have... -22mm hollow torsion bars -Tarett front sway bar -Rebel Racing front raised bilstein struts -Rebel Racing rear adjusted coil over kit, springs not yet aquired -rear sway bar, not yet decided -2.8 MFI 911 engine, est 200hp -901/914 trans, custom gearing, Trans-Gaurd LSD -Boxster calipers -17" Fikses, 8" front and 9" rears (GT fenders installed on car) Educated opinions? Cheers |
sport....
ok ill elaborate....
my setup 22mm torsion bars koni reds tarett sway M calipers rear: bilstein sports- 225 lb springs colemanracing.com threaded perches... stock sway |
Yellow ones.
| All times are GMT -8. The time now is 09:52 AM. |
