Locate Swaybar
Does anyone know how to locate where to drill the 1-inch hole for the front sway bar???? I'm installing a Weltmeister front sway bar on a 72 914. I read the tech article on this site and have the template printed out. The template indicates you should have 1/2 inch from the top of the arch but what about locating the hole left and right(front and aft) of the arch???? Is it not as critical as the up and down location? Not only that how do I know where exactly to measure the 1/2 inch from??? Center of the arch? I just don't want to drill the holes and later find that the bar is binding because of the holes I drilled. Maybe its just not that critical...........????
Any and all help appreciated!
Alex
Old 11-05-2006, 08:34 PM
I have installed a front sway bar recently, and i measured the 1/2 inch from the center of the arch.(to the top of the template)
I used tape to hold the template, and center it to middle of the prestamped lokation im the body.
He are some pictures, maybe you can use them
Old 12-20-2006, 01:26 PM
