Charging problems
I purchased and installed a new (rebuilt) alternator from a source we all know and love...
Charging lite stays on, 11.38 volts at the battery during 2000 RPM idle...
Used a voltmeter and picked up the red wire in the plug on the harness from the Alternator that connects to the relay board and a ground...Getting a strange reading of less than 1 volt...
Voltage Regulator original...
Any ideas...
2-OH!
Old 12-20-2006, 02:09 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Is everything connected? Say, the red wire from the alternator perhaps not hooked up to the stud on the starter solenoid?
Uhh, not that I did that myself.
More than once.
In a row...
--DD
Old 12-21-2006, 08:45 AM
Dave:
As we speak, I am down loading and printing the diagrams from your site...Everything is hooked up correctly according to the Haynes diagram...And I (like you) never have to re-connect anything, I always get it right the first time...
However, Murphy and I are going to check and recheck this project over the next few days, step by step, to make sure...
My concern is that I am only getting a few volts to the plug on the relay board and in my opinion, I should be getting at least 13.XXX...
RE
Old 12-21-2006, 09:15 AM
Dave:
Fixed it...As usual, I was the problem...
I had a new quad gauge built by NHS (and yes it's a thing of beauty) and it has an LED bulb instead of the incandescent normally used...They gave me a diagram on how to slave a regular bulb "in-line" to make the system work...
But I choked, hooked it up wrong and was therefore getting bumpkis out of the system because the element in the bulb was not in the system...
Murphy and I re-wired the system behind the new gauge and "What do ya know" it works just like it's supposed to...
Thanks for all your help...
2-OH!
Old 12-27-2006, 01:48 PM
