Wiring at the horns on 75 914
Like a Dummy (call me Lamont Sandfer) I forgot to mark the Horn wires on my 75 914 when I tore the car down. Now it is repainted and I am putting it back together, and was wonderering if someone could help me out on the correct wiring on the horns.
Each horn has 2 lugs. Which color wire goes where, or does it matter?
Thanks, I appreciate your help
Rob K
Old 01-04-2007, 06:59 AM
Banned for Life
RSBob's Avatar
I am no expert, but really doubt it matters as long as you have a positive and a ground going to each side you should be good.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 01-04-2007, 09:06 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Check to see if either lug has a connection with the mounting bracket area. If so, that one should be your ground. Brown wire (with no stripe) == ground.
--DD
Old 01-04-2007, 02:01 PM
As far as I can tell, neither lug is tied to ground.
Old 01-08-2007, 04:56 AM
Administrator
If that's the case, then it probably doesn't matter which way around the wires go.
--DD
Old 01-08-2007, 06:29 AM
