Banned for Life
RSBob's Avatar
Removed Fuel Gauge and now it blows
fuses.
I took out the fuel gauge to remove the glass from the bezel for cleaning. I meticulously marked which bulbs and wires go where. However, a couple of the black plastic/rubber sleeves fell off a couple of the bulbs holders which I thought I accurately replaced. The only bulb without a sleeve was the most inboard bulb with only one black wire. After reinstalling all, I blow out the fuse to the gauges/fuel level/parking brake light.
If I had 10 fuses to sacrifice, I would connect the wires/bulbs one by one to find out which one was the culprit- but don't have the luxury.
What did I miss?
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 01-14-2007, 03:46 PM
Banned for Life
RSBob's Avatar
This is what I missed. I must have crossed the connections between the ground wires and the green wire. Everything works except the bulb which illuminates the gauge. It is getting power and the bulb looks fine. Will try switching bulbs and see if that's it.
OK, everyone move along. Nothing to see here.
Old 01-19-2007, 08:29 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If switching bulbs doesn't solve it, then it is most likely a ground problem. Some bulbs ground through the gauge housing, which in turn must be grounded for them to work. Others have a separate ground lug.
--DD
Old 01-20-2007, 06:56 AM
Banned for Life
RSBob's Avatar
Dave, I switched bulbs and you were right. What's interesting is that the bulb that no longer works has what appears to be a good filament. I would imagine these are the same bulbs used for 911s as well. Time to support the BB sponsor and stock up.
Old 01-20-2007, 08:26 PM
